Retarget ITM printing with Newlib
1,204 次查看
jeff_hane
I want to use the ARM CMSIS DSP library on the k28 board I am using.  I've got everything building and running but there is something strange happening with printf.  I enable SWO on the board and compile in retarget_itm.c.  However, I only ever get the first printf on the SWO ITM console.  If I place a breakpoint in _write, it will enter it once but never again.  The program continues to run just fine but no output on the console.  I't like the link to _write got lost so calls to printf never show up again.
thanks,
jeff
1,135 次查看
jingpan
Hi Jeff,
What IDE do you use?
Jing
1,135 次查看
jeff_hane
Hi Jing,
  I use mcuxpresso; however I went back and figured this out last week.  There was a buffer overrun in my code that was somehow breaking my second printf.  The code would run fine and get the correct results but just that one printf wouldn't work.
thanks,
jeff
