Hi, Sawa
Sorry, I have to recommend Kinetis K series or E series which has complementary output for your reference. As you know, TPM is not good recommend function for DC motor for dead time handling. If you have to use this module, I give you two direction for your reference.
1. Select a complementary output H-bridge driver.
2. Set PWM phase by software setting. But this direction only can use on slow speed motor control.
Hope my reply can help you.
Best Regards
Paul
