In some previous question I received the advice to follow the design of the TWR-K21F120MA in order to do my own board for the MK22FN1M0AVMC12, and so I did.
Now I am doing a final revision of the design but I found that there is another tower kit TWR-K22F120M that I would say has a microcontroller that is more similar to the one I am using (MK22FN1M0AVMC12), only with half of the flash memory.
Although the two designs seem similar for the microcontroller connections, there are some differences, and I was wondering if I should modify my design and check in detail the schematic of the TWR-K22F120M, or if I should stick to the design that I already did following the TWR-K21F120MA as a reference design. Would it make any difference / Improvement, in principle, would my design work if I follow any of those two TWR reference designs?
Thank you in advance!
Ivan
已解决! 转到解答。
Hello Pulsatrix P1,
I think this post may help you out:
Take care, MK22FN1M0AVMC12 should refer to TWR-K21F120M, even the name of MK22FN1M0AVMC12 seems similar as TWR-K22F120M, but the chip on TWR-K22F120M have a lot of difference with MK22FN1M0AVMC12.
So, don't hesitate to refer to TWR-K21F120M.
Kerry
Hello Pulsatrix P1,
Kerry
Hi Ivan,
K22 really have a lot of part number, so just refer to the post which I give you, I also refer to that post.
Kerry
Hi Ivan,
If you still have question about this topic, just let me know!
If your problem is solved, please help me to mark the correct answer, just to close this post, thank you!
Kerry
