RTC problem for K60
RTC problem for K60
1,659 次查看
AaronsCook
Hi, All
I have a question for K60's RTC. The RTC has VBAT power-supply and OSC 32.768 as clock.
But how can I make sure that the RTC is Running When the chip power down and re-power?
Is it ture to read the RTC millisecond counter and to judge it not zero?
wang
1,186 次查看
eduardo_viramon
Wang,
In fact that is the case, once awake MCU can check the RTC counter register to detect change to the counter. Read the reference manual in detail to understand the cases where the counter may be read as zero like counter overflow or invalid time.
Eduardo
1,187 次查看
eduardo_viramon
Wang,
Eduardo
1,186 次查看
AaronsCook
Hi, Eduardo
Thank you for your help~
Wang
