Hello!
I have one question.
If I programmed my K64F board by using bin. or .hex file and "drag and drop" method will all flash also be erased?
Regards!
解決済! 解決策の投稿を見る。
Hi Tomasz Sobiech
It will depend on the OpenSDA debugger interface. Most of the application perform a mass erase before flashing your program.
Hope this helps.
TIC
Hi Tomasz Sobiech
Hope this helps.
TIC
