Program stuck in __aeabi_uldivmod in KEA64
1,639 次查看
mohmdshibin
I am using KEA64 evaluation kit and JLink debugger in CodeWarrior. But the program is stuck in __aeabi_uldivmod. I have no idea why it is happening. Please share your thoughts on the issue.
Thank you!
1,531 次查看
mohmdshibin
The software stuck in function __init_hardware() in startup code.
1,531 次查看
kerryzhou
Hi Mohammed,
    Please tell me your KEA64 full name, then check it with your project, do you select the correct chip with your project?
   I need to make sure your project and the KEA64 chip is match, as you know the KEA64 have the S9KEAZN64xxx and S9KEAZ64xxx, these two chip have a lot of register difference. Please check this point at first.
   Besides, you also can create a new empty project for your KEA64 in the CW, can you also meet this stuck problem?
Kerry
