Processor Expert and GPIO LDD on Kinetis
3,702 次查看
Jeinstei
I'm not sure if I should throw this here or in the Codewarrior forums, but lets see what people think.
We can't seem to find a wya to use the GPIO_LDD to set pull up or pull down for any pins. While the Init_GPIO bean can do it, are we missing some option in the GPIO_LDD that can enable pull up or pull down for specific pins?
Thanks.
5 回复数
1,739 次查看
ProcessorExpert
Senior Contributor III
the attached pdf should help you to set the pull-up in GPIO_LDD. However in future this behaiour should be improved.
best regards
Vojtech Filip
Processor Expert Support Team
1,739 次查看
ETCTim
Could you please post the PDF again?
1,739 次查看
BlackNight
If it is about using pull-ups and pins with BitIO_LDD, then this might be helpful:
Tutorial: Bits and Pins with Kinetis and the FRDM-KL25Z Board | MCU on Eclipse
Hope this helps.
1,739 次查看
ETCTim
Yup. Great. Thanks,
1,739 次查看
Jeinstei
Thanks for that. We'll work with it this way for now. Hopefully it can be integrated a bit better in the future!
