Hello supporte team,
can you please give some guidance, how to port the LIN driver
from FRDM-KW38
to FRDM-KE04Z?
SDK FRDM-KW38: v2.6.14
SDK FRDM-KE04Z: v2.11.0
If there is a document, which descirbes the process of porting a driver in general, it would be highly appreciated.
Thank you for your support.
There is no a document to migrate the LIn driver for the KW38 to the KE04
The KE04 is the commercial version of the KEA family I recommend that you check the driver for the KEA and you can migrate to the KE04, that will be much easier than migrating the KW38 driver
Please check the following links
https://www.nxp.com/webapp/Download?colCode=SAMPLE-DRIVER-FRDM-KEA-S32DS
https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=SW-LIN2X-J2602-D
I hope this will help you.
