Play Wav file
Play Wav file
1,342 次查看
aniketmarkande
Hello All,
I am trying to run audio file (.wav) using SDK 2.0 USB stack on kinetic K22 controller. I am sending data from controller to PCM2706C (which is stereo audio DAC with usb interface IC) and is connected to speaker (single speaker).
I am reading data from the wave file in uint8_t buffer and sending to the speaker using USB_HostAudioStreamSend(). The sound file is not getting played as it should be and dont know whats wrong.
Wav file details: encoded with 16-bit pcm, mono channel, 32000Khz sampling freq.
Aniket
标签 (2)
1,078 次查看
jingpan
I replayed you at original ticket.
Jing
1,078 次查看
aniketmarkande
please respond. Its urgent.
Thank you.
