I'm currently using PORT digital filter functionality on a K60 100 MHz BGA 121 pin. It has been detailed in chapter 11 of the rev.1 Reference Manual.
I have noticed it is completely disappeared from the rev.2 Ref. Manual and this absence is not mentioned at all in the Kinetis 100 MHz Rev 1.x to Rev 2.x Migration Guide, although it is still present in chapter 5 (clock distribution).
Has Freescale only forgotten the filter in the new manual or has it been removed from the new revision?
Does anybody know anything?
Thanks. Best regards.
Cesare
Solved! Go to Solution.
Hi Cesare,
Many apologies. That section was inadvertently removed during that June update. This was NOT removed in Revision 2 of the silicon. The previous version of the reference manual included the PORT registers, but this issue has already been flagged to our Tech Docs team for the next reference manual release due out before the end of the year.
I hope that this helps and sorry for this confusion.
Carlos
Hi Cesare,
Carlos
