First project that did not work from POR was created with GNU C Compiler toolchain. The new one derived from LED test is with Codewarrior ARM C Compiler toolchain and is working fine also from POR.
Now the evaluation can continue :smileyhappy:.
Thank you santiago.gonzalez and PSA for suggestions.
In process i discovered two potential bugs in ProcessorExpert that I will present in fresh discussion.
br,
Ben
