Mark,
Thank you so much for your help. I really hope this runs, as what you typed above is exactly what I thought. I have two concerns though:
1. In the Teensy, the MKL02 chip is not on the USB lines, so I believe it houses a static bootloader that loads onto the MK20 chip and then, using that code, the MK20 pulls the elf file through the USB. So, my concern is that my loaded code with JTAG will not run without the bootloader that comes from the MKL02 chip. I am a beginner here, but I fear that on power up the MK20 program counter goes to where the bootloader code would normally live.
2. Do you think there is any difference to teh binary with the MK20DX256VLH7 vs. MK20DX256VLL7?
Thanks again.
Tim
