MTTF/FIT values available for the Kinetis E series
1,212 次查看
jun1
Hi.
Are MTTF/FIT values available for the Kinetis E series at all?
I would like to use it in a design but no reliability data is a dealbreaker...
Thanks!
1,118 次查看
kerryzhou
Hi jun yamada
   Please check this information:
Wish it helps you!
Kerry
1,119 次查看
kerryzhou
Hi jun yamada
Wish it helps you!
Kerry
1,118 次查看
jun1
Thank you very much. It was helpful.
