MSCAN CRC on CAN Message
543件の閲覧回数
harish_shekarap
The MSCAN CAN example CAN_CheckSendBufferFrame transmits the Data on the CAN bus, I wanted to know whether the CAN message is sent with CRC? or do we need to manually calculate the CRC and add to the Frame buffer?
タグ(1)
2 返答(返信)
462件の閲覧回数
Robin_Shen
Hi Harish Shekarappa,
You don't need to manually calculate the CRC and add to the Frame buffer.
About the software, you can download the latest MCUXpresso SDK.
I don't know which Kinetis MCU are you using. If KE06 or KE16 are used, please refer the CAN examples in SDK_2.5.0_FRDM-KE06Z or SDK_2.5.0_FRDM-KE16Z.
...\SDK_2.5.0_FRDM-KE16Z\boards\frdmke16z\driver_examples\mscan\interrupt_transfer
...\SDK_2.5.0_FRDM-KE06Z\boards\frdmke06z\driver_examples\mscan\loopback_transfer
Robin
462件の閲覧回数
mjbcswitzerland
Specialist V
CRC is generated in the HW on transmission and check in the HW in reception. I don't think that any CAN controller will require it to be done in SW.
Mark
