MKL26Z128CAL4 number of flash blocks?
daniel3550
The chip configuration chapter section 3.6.1 does not have information for MKL26Z128CAL4. This was a new 36 pin device that was added as an addendum to the reference manual (Version 3.3).
Does the MKL26Z128CAL4 have 1 or 2 blocks of flash?
Tags (2)
kerryzhou
Hi Daniel Darden,
  I get the reply that the MKL26Z128CAL4 flash block size is 128K, it means, this chip just have one block.
Wish it helps you!
Kerry
kerryzhou
Hi Daniel Darden,
Wish it helps you!
Kerry
kerryzhou
Hi Daniel Darden,
    Thank you for your document content lack problem report.
   About this question, I already check it with our according department.
  After I get reply, I will let you know ASAP.
   Please wait patiently now, thanks a lot for your understanding.
Kerry
