MKL26Z128CAL4 number of flash blocks?
1,187件の閲覧回数
daniel3550
The chip configuration chapter section 3.6.1 does not have information for MKL26Z128CAL4. This was a new 36 pin device that was added as an addendum to the reference manual (Version 3.3).
Does the MKL26Z128CAL4 have 1 or 2 blocks of flash?
タグ(2)
1,077件の閲覧回数
kerryzhou
Hi Daniel Darden,
  I get the reply that the MKL26Z128CAL4 flash block size is 128K, it means, this chip just have one block.
Wish it helps you!
Kerry
2 返答(返信)
1,078件の閲覧回数
kerryzhou
Hi Daniel Darden,
Wish it helps you!
Kerry
1,077件の閲覧回数
kerryzhou
Hi Daniel Darden,
    Thank you for your document content lack problem report.
   About this question, I already check it with our according department.
  After I get reply, I will let you know ASAP.
   Please wait patiently now, thanks a lot for your understanding.
Kerry
