MKL16 how to run in VLPRCO(Very low power run mode current in compute operation)
2,915 次查看
jiannianli
Hi , I need to let MKL16 work in low power ,  and now the current is very low in LLS mode . but when it work in VLPR and  do some data calculation ,the current is up to 1.4ma  . I had read the document and find VLPRCO mode ,  so how the mkl16 run to VLPRCO from VLPR ?
thank you.
7 回复数
2,730 次查看
kerryzhou
Hi Li ADai
  About the VLPR computer mode detail operation, I suggest you refer to the KL25 bare-metal code, which can be downloaded from this link:
https://www.nxp.com/downloads/en/lab-test-software/KL25_SC.exe
KL25 Sample Code\kl25_sc_rev10\klxx-sc-baremetal\build\keil\low_power_demo
              case 0xf://Coremark in VLPR
                /*Maximum clock frequency for this mode is core 4MHz and Flash 1Mhz*/
                if ((SMC_PMSTAT & SMC_PMSTAT_PMSTAT_MASK)== 1){
                 printf("  in RUN Mode moving to VLPR\n\r ");
                    printf("Press any key to enter VLPR\n\r ");
                    uart0_getchar(UART0_BASE_PTR);
                    printf("Configure clock frequency to 4MHz core clock and 1MHz flash clock\n\r ");
                    vlp_clock_config(BLPE);
                    /*Go to VLPR*/
                    clockMonitor(OFF);
                    enter_vlpr();   // get out of VLPR back to RUN
                if ((SMC_PMSTAT & SMC_PMSTAT_PMSTAT_MASK)== 4){
                 printf("  in VLPR Mode !\n\r ");
                } else if ((SMC_PMSTAT & SMC_PMSTAT_PMSTAT_MASK)== 1){
                 printf("  in Run Mode  !\n\r ");
                    clockMonitor(ON);
                op_mode = what_mcg_mode();
                if (op_mode ==1)
                    printf("in BLPI mode now at %d Hz\r\n\r",mcg_clk_hz );
                if (op_mode ==2)
                    printf(" in FBI mode now at %d Hz\r\n",mcg_clk_hz );
                if (op_mode ==3)
                    printf(" in FEI mode now at %d Hz\r\n",mcg_clk_hz );
                if (op_mode ==4)
                    printf(" in FEE mode now at %d Hz\r\n",mcg_clk_hz );
                if (op_mode ==5)
                    printf(" in FBE mode now at %d Hz\r\n",mcg_clk_hz );
                if (op_mode ==6)
                    printf(" in BLPE mode now at %d Hz\r\n",mcg_clk_hz );
                if (op_mode ==7)
                    printf(" in PBE mode now at %d Hz\r\n",mcg_clk_hz );
                if (op_mode ==8)
                    printf(" in PEE mode now at %d Hz\r\n",mcg_clk_hz );
                printf("\n\rTransitioning from VLPR mode \n\r");
                for (i=0;i<2;i++)
                     printf("Starting running Coremark in VLPR with--- CPO mode enabled. \n\r   ");
                     //enable_systick(0x00002000);
           enable_systick();
                     /* In compute mode */
                     MCM_CPO |= MCM_CPO_CPOREQ_MASK;
                     while(!(MCM_CPO & MCM_CPO_CPOACK_MASK));
                     wait();
                     main_app(); //CoreMarks
                     /* Get Out of compute mode */
                     if(MCM_CPO & MCM_CPO_CPOACK_MASK){
                          MCM_CPO &= ~MCM_CPO_CPOREQ_MASK;
                          while (MCM_CPO & MCM_CPO_CPOACK_MASK);
                     } else{
                       printf("Exiting test early - Did you disable LPTRM interrupt? \n\r");
                       break;
                     printf("  Back in VLPR mode \r\n");
                     printf("Starting running Coremark in VLPR without CPO mode enabled. \n\r");
                     printf("Coremark iterations = 0x%02X of 2 \n\r",i) ;
                  break;‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
            case 0x14: // enter compute mode
                 printf("  in VLPR Mode !  ");
                    wait_count = 20000000;
                 printf("  in Run Mode  !  ");
                    wait_count = 200000000;
                    // The next line is to resolve an errata where the LOCK bit is cleared in CPO
                    MCG_C5 |= MCG_C5_PLLSTEN0_MASK; // set PLLSTEN to keep PLL LOCK bit from clearing
                if (op_mode ==1)
                    printf("in BLPI mode now at %d Hz\r\n",mcg_clk_hz );
                if (op_mode ==2)
                if (op_mode ==3)
                if (op_mode ==4)
                if (op_mode ==5)
                if (op_mode ==6)
                if (op_mode ==7)
                if (op_mode ==8)
                printf("Start Compute Mode --> waiting for %d counts   ", wait_count);
                enable_systick();
                wait();
                for (i=0;i<wait_count;i++){
                     if(!(MCM_CPO & MCM_CPO_CPOACK_MASK))
                           break;
                printf("         \n\rWaiting is Over - Now OUT of Compute Mode\n\r ");
                break;
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
2,730 次查看
jiannianli
I had try and it work ok ,  thank you very much
2,730 次查看
kerryzhou
Hi Li ADai,
   You are welcome.
   That low power code is the complete code, and can be used in the KL16 series.
   Wish it helps you!
Kerry
2,730 次查看
jiannianli
Hi ,Kerry
thank you very much.
now I still have some questions .  there are 2 code test under ,why the current so high when do some compute ? I need calculate some float data .
Current difference is:   1.26ma-348ua=912ua
//************code test 1:do_Some_compute****************************************
// takes 1.26ma in compute mode ,and 1.414ma will take if not enter compute mode ,
enter_vlpr();
//enter In compute mode
while(!(MCM_CPO & MCM_CPO_CPOACK_MASK)){};
while(1)//
do_Some_compute();
//ouot compute mode
//************code test 2: do nothing *****************************************
// takes 348ua in compute mode, and 556ua will take if not enter compute mode ,
enter_vlpr();
while(1)//
// do_Some_compute();
//ouot compute mode
2,730 次查看
kerryzhou
Hi Li ADai,
   My understanding is the compute operation code execution also consumes the power. That's why the datasheet test the power consumption with while(1) loop executing.
   Wish it helps you!
Kerry
2,730 次查看
jiannianli
Hi ,Kerry:
 thank you very much .
I will try other way to reduce the power .
2,730 次查看
kerryzhou
Hi Li ADai,
  You are welcome!
  If you have any other question, welcome to create the new case about it.
Kerry
