MKE18F512VLH16 connection failure via swd
448 次查看
AshPugczup
Hello I designed my own custom board with MKE18F512VLH16 and when I try to connect jlink to it I get communication failure and error that it can't connect to MDM-AP
标签 (1)
1 回复
358 次查看
Joey_z
Hi,AshPugczup
Have you successfully connected J-link to board before ? If you have been successful before, I suspect that your MCU is locked up. if not , you should check for other hardware issue with your bord.
Joey
