MKE06 SPI
MKE06 SPI
1,445 次查看
binchengtao
There is no problem with SPI transmission. How do you judge the end of the transmission according to the routine? The situation I encountered is this: always in the first send does not end
1,339 次查看
Robin_Shen
Hi bincheng,
About the typical usage, have you try to use another SPI send char 13?
This example sends zeros repeatedly until it receives a character with code 13 from the slave.
Robin
1,339 次查看
binchengtao
How to set the acceptance of SPI communication is valid on the second edge of the clock detectionNever get a response after sending a messageThe picture is the communication requirement of the SPI slave. Please help to configure the SPI configuration of the MKE06 chip.
1,339 次查看
Robin_Shen
Maybe you need to reconfigure the SPI clock format shown below:
Robin
