Hi.
I am always indebted.
Regarding the subject of the title, unused pins will follow the answer below.
Configuration for Unused Pins/GPIOs on Kinetis
So the question is, does “Disabled” mean that the register settings are as follows?
-Input is disabled (GPIOx_PIDR [PID] = 1)
-Output is disabled (GPIOx_PDDR [PDD] = 0)
-Internal pull-up is disabled (PORT_PUE (L / H) [PTxPEn] = 0)
-High drive function disabled (HDRVE = 0x00)
Thank you.
已解决! 转到解答。
Pins are disabled or analog by default. You needn't configure them.
TIC
- We are following threads for 7 days after the last post, later replies are ignored
TIC
