MK64FX512 clock setup
499 次查看
wimdekimpe
On a new board I am trying to get the clock configured on the MK64X512xxx12.
I started from a FRDM-K64F project - I have such a board as well - and then tried to move the project to my new board.
When stepping through the code, it seems to get stuck on the clock configuration. So I figured, ok, clocks on my hardware is different, so I just need to change the clock configuration to match my hardware.
I tried to use the clock tool on MCUXpresso to generate the proper code, but it allways seems to get stuck in the function
BOARD_BootClockRUN
and always when calling
CLOCK_BootToPeeMode
I tried to use the internal 48 MHz clock, the external crystal oscillator (my board has a 16 MHz crystal connected between the EXTAL0 and XTAL0 pins), but nothing seems to work.
However, if I just skip the clock configuration and take the default power on reset values, then my example does work, but then I have a clock of about 20 MHz, while I would like to run it on 120 MHz.
Any ideas?
386 次查看
Robin_Shen
Hi Wim,
Have you try to select 'Using oscillator with external crystal(low power)' as OSC mode?
I have attached the file generated by online MCUXpresso clock tool, so that you can test it on the custom board.
Robin
