I can not make the software run on a machine Medical_GUI 64bits.
Following is the error:
C:\Freescale\Medical GUI>java -jar medical_gui_v2.2.jar
Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: gnu/io/Co
mmPortIdentifier
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:2451)
at java.lang.Class.getDeclaredMethod(Class.java:1954)
at java.awt.Component.isCoalesceEventsOverriden(Component.java:6190)
at java.awt.Component.access$500(Component.java:188)
at java.awt.Component$3.run(Component.java:6144)
at java.awt.Component$3.run(Component.java:6142)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Component.checkCoalescing(Component.java:6141)
at java.awt.Component.<init>(Component.java:6110)
at java.awt.Container.<init>(Container.java:276)
at java.awt.Window.<init>(Window.java:437)
at java.awt.Window.<init>(Window.java:594)
at java.awt.Dialog.<init>(Dialog.java:665)
at java.awt.Dialog.<init>(Dialog.java:409)
at javax.swing.JDialog.<init>(JDialog.java:271)
at Medical.PortChooser.<init>(PortChooser.java:99)
at Medical.MedicalCommander.<init>(MedicalCommander.java:65)
at Medical.MedicalControl.<init>(MedicalControl.java:38)
at Medical.MedicalControl$1.run(MedicalControl.java:62)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:251)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:727)
at java.awt.EventQueue.access$200(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:688)
at java.awt.EventQueue$3.run(EventQueue.java:686)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDo
main.java:76)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:697)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThre
ad.java:242)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.
java:161)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThre
ad.java:150)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
Caused by: java.lang.ClassNotFoundException: gnu.io.CommPortIdentifier
at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
at java.lang.ClassLoader.loadClass(ClassLoader.java:423)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
... 34 more
