MCU型號更改且無法燒入
MCU型號更改且無法燒入
JetWen
您好,我已經改過IAR上型號的部分以下是Error Message,請問是哪裡出問題(已經改過MCU型號)?
RaRo
Hello @JetWen,
It seemed that has something to do with the change in the MCU model.
Could you please tell which model have you had and for which one you change it?
Best regards, Raul.
JetWen
Hello! RaRo,Sorry for replying so late,our currently using MCU is MKL26Z128VLH4,and we are going to replace to MKL26Z256VLH4
RaRo
Hello @JetWen,
It seems that your issue has something to do with your memory configuration.
The MKL26Z256VLH4 has different memory values than the MKL26Z128VLH4, so it might be a good idea to modify your memory configuration for the new device.
[KL26P64M48SF5. Ordering Information]
[KL26P121M48SF4. Ordering Information]
Just for double check, could you please check and modified your memory configuration if needed?
Warm regards, Raul.
