I am looking for a Kinetis development kit that has a touch screen with graphics screen and sound. Not sure what processor is needed. This is low cost experiment so I need to keep everything as cheep as possible.
Hi Daniel,
If you look for a QVGA resolution display (Smart display) you can use TWR-LCD with a TWR-K60D100 (for example). If you look for a bigger display a non smart display, you can use TWR-LCD-RGB board, in this case you will need a processor with LCD controller inside. And you need the TWR-ELEV and TWR-SER will be useful.
So, two configurations:
A) TWR-K60D100M-KIT + TWR-LCD
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=TWR-K60D100M&tid=m32TWR
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=TWR-LCD&tid=m32TWR
B) TWR-K70F120M-KIT + TWR-LCD-RGB
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=TWR-K70F120M
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=TWR-LCD-RGB&tid=m32TWR
For audio, for both configurations, TWR-AUDIO-SGTL
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=TWR-AUDIO-SGTL&tid=m32TWR
You can use MQX RTOS, www.freescale.com/mqx
And one of the graphic libraries, www.freescale.com/eGUI or www.freescale.com/PEG
You have more options or combinations with the Tower system, but this is a good starting point.
Luis
What the difference between a smart display and nonsmart display.
Is there some demos we can down load with these kits.
Date: Tue, 7 Oct 2014 14:06:52 -0700
To: danieljackmorley@hotmail.com
Subject: Re: - Looking for a Kinetis Kit
reply from Luis Casado in Kinetis Microcontrollers - View the full discussion
Hi Daniel,
Luis
Did your question get answered?
If so, say thanks by clicking Correct Answer in the community thread!
Reply to this message by replying to this email, or go to the message on Freescale Community
Start a new discussion in Kinetis Microcontrollers by email or at Freescale Community
Following Looking for a Kinetis Kit in these streams:
Inbox
A Smart display has the RAM frame buffer and the screen controller integrated, you need to refresh constantly the display.
Luis
What is the TWR-SER needed for?
Date: Tue, 7 Oct 2014 14:27:52 -0700
Luis
Inbox
Enable wired connectivity. http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=TWR-SER&tid=m32TWR
Luis
This project does not required USB or Ethernet
MQX RTOS is this a complier. What kind of tutorials offered that can get me up to speed on operating system assuming they are required.
Luis
Inbox
MQX is an RTOS, you can use different IDE's , CodeWarrior, KDS, IAR, Keil,..
You can find documents and tutorials under www.freescale.com/mqx
http://www.freescale.com/webapp/sps/site/training_information.jsp?code=WBT_MQX_RTOS_COURSE
Luis
Looking for the cheapest route but I am familiar with code warrior.
Date: Tue, 7 Oct 2014 14:42:54 -0700
http://www.freescale.com/search?&q=MQXinmeta:Asset_Type%3DTrainingsinmeta:type%3DOn%2520Demand&dnavs=inmeta:Asset_Type%3DTrainings+inmeta:type%3DOn%2520Demand&client=search_training&site=fsl_en&output=xml_no_dtd&proxystylesheet=search_style_fe&filter=0&getfields=*&rc=1&ie=UTF-8&ulang=en&access=p&sort=date:D:L:d1&entqr=3&entqrm=0&oe=UTF-8&ud=1&lang_cd=
Luis
Inbox
