We are planning to use MKW36A512VHT4 part in one of our wireless system designs. Our design requires 10 years of longevity. So please share the longevity/EOL details of the same.
Expecting a quick resolution.
Thanks and regards
Solved! Go to Solution.
Hi Ajith K Asok ,
You can check the kinetis chip longevity from the following link:
It will be end in 2018+15=2033, it can meet your product 10 years longevity.
Kerry
Hi Ajith K Asok ,
Kerry
Thank you for the quick response.
Hi Ajith K Asok,
You are welcome!
If your question is solved, please help me to mark the correct answer, just to close this case, thanks.
Kerry
