Kinetis second set of ftm registers
999件の閲覧回数
tommyp
The Kinetis Kx manual makes reference to the "Second set of registers" when FTMEN is 1.  Can anyone clarify how to identify what registers are considered the second set?
821件の閲覧回数
mjbcswitzerland
Specialist V
Hi Tom
Compare the TPM register set in a KL device with the FlexTimer set in a K device.
You will see that FTMn_CNTIN, FTMn_MODE, FTMn_SYNC, FTMn_OUTINIT, FTMn_OUTMASK, FTMn_COMBIN, FTMn_DEADTIME and FTMn_EXTTRIG, FTMn_FSM, FTMn_FILTER, FTMn_FLTCTRL, FTMn_QDCTRL, FTMn_FLTPOL, FTMn_SYNCONF, FTMn_INVCTRL, FTMn_SWOCTRL and FTMn_PWMLOAD are only available in the FlexTimer.
These can only be used when FTMEN is set, otherwise the FlexTimer's first set of registers allow it to work in (restricted) TPM compatibe mode.
Mark
Kinetis: µTasker Kinetis support
For the complete "out-of-the-box" Kinetis experience and faster time to market
