Kinetis NMI pin as normal GPIO
已解决
跳至解决方案
2,374 次查看
hanisamara
i am trying to use PTB4/NMI pin on the KEA128 as normal GPIO. During debug it is still Low but after reset it remains High. i configured the NMI bit in SIM_SOPT0 to 0: SIM_SOPT0 &= ~(SIM_SOPT0_NMIE_MASK); /* set NMI pin as normal GPIO (PTB4) */
after that i declare the pin as output and set it to low.
did i miss any thing?
Hani
标签 (1)
标记 (3)
1 解答
2,163 次查看
Alexis_A
Dear hanisamara‌,
Please check the following post:
https://community.nxp.com/message/921860
I think this could help you with this issue.
Alexis Andalon
在原帖中查看解决方案
1 回复
2,164 次查看
Alexis_A
Dear hanisamara‌,
Alexis Andalon
