Kinetis K27 Absolute maximum rating voltage of USB1_VBUS pin
1,099 次查看
masahirokiniwa
Could you tell me the absolute maximum rating voltage of USB1_VBUS pin on Kinetis K27?
I see its tolerant  voltage is 5V in data sheet P.59. But I couldn't find its absolute maximum rating.
How voltage can I applied to it?
M.KIniwa
986 次查看
Hui_Ma
K27 product is using the same High speed USB module with K26 product.
Customer could refer K26 datasheet about USB1_VBUS Max. rating:
Wish it helps.
Mike
987 次查看
Hui_Ma
Wish it helps.
Mike
