Kinetis K10 M10AFV / M10AEV
849件の閲覧回数
PepitoPomponio
We have several Kinetis K10 LQFP microcontrollers, some of them are marked as M10AFV an other as M10AEV.
Somebody knows what that code means?, what is the Part Identification Number related to that code?.
Thanks in advance.
Diego
4 返答(返信)
600件の閲覧回数
jeremyzhou
Hi Diego,
I was wondering if you can sharing the total product number of the several K10 LQFP micro controllers.
I'm looking forward to your reply.
Ping
600件の閲覧回数
PepitoPomponio
Hi Jeremy,
Some of the packages are marked as (from top to bottom):
M10AEV
1N86B
CTXX7AN
We know the second and third codes are the Mask Id, so as to take a look of the ERROR MASK List given by Nxp.
However, the first one "M10AEV" should tell us what kind of microcontroller we have.
Probably "M10" would mean that is a Kinetis K10 Series, but "AEV" should be related to the Part Id Number, mainly to know memory size.
Thanks in advance,
Diego
600件の閲覧回数
jeremyzhou
Hi Diego,
Thanks for your reply.
After I confirmed, the M10AEV stand for the these K10 as follow.
Header 1
MK10DX32VFM5
MK10DX32VFT5
MK10DX32VLF5
MK10DX32VMP5
Hope it helps.
Ping
600件の閲覧回数
PepitoPomponio
Thanks Jeremy, It seems to be Ok for this case, but for other Kinetis marks....?
Would you mind to let me know which document you are lookin at?.
Because, I could find any document from NXP (Freescale) explaining this codes.
Thanks in advance,
Diego
