Kinetis Flexbus timing
1,055 次查看
Burba
I'm searching a detailed flexbus timing for the K10...K60/ 100 mask. I'm e.g. missing hold time ALE Low to Address valid and also Data valid from CS going high. Where can I find it?
The EZPORT timing is given much better within the family datasheets.
FB
691 次查看
Burba
Now I know why I even did not get any aswer from freescale. I've done some measurements by myself and found that the adress hold time from ALE going Low is 0 or even little bit negative. That mean that you must use one additional waitstate for ALE for multiplexed flexbus write acces which is a very bad situation and totally waste of performance. With a very fast RAM you waste about 30% of flexbus throughput. I just wonder if the same problem exists on other Cortex M3 devices from other brands.
691 次查看
apanecatl
Senior Contributor II
Hi Helmut, please check my answer in your inbox.
691 次查看
luke_8
try to send Service Request with high priority
