Hi Lucian
What happens if there is a power down event, worst case scenario ?
In the case of the external flash, the worst case scenario is that the image is corrupted, but it will never be loaded to the internal flash, so it does't represent a big problem. in the case that you power down in the load to the internal flash, your application will be corrupted, but if you erase your flash, it should recover its normal operation
Hope this information helps you
Jorge Alcala
