KW36: Sending Wireless uart send uart stream to phone gets error sometimes
567 次查看
skalyan2
I am using KW36 W_uart example, KW36 acts as slave, i am trying to send some wireless uart data from KW36 to phone(Samsung A30) , when KW36 trying to send one particular wireless uart data,the below error has come.
What is the issue of the below snapshot, can you please explain the problem and the possible solution ?
Many thanks in advance!
Sai Kalyana Raman
标记 (2)
466 次查看
estephania_mart
Do you have this behavior with all the mobile phones or is this only happening with that specific model ?
Estephania
466 次查看
skalyan2
Hi Estephania,
I have tested only with two mobiles , Samsung A30 (Android version: 9.0), pixel 3(Android version: 9.0) and it is reproducing in both the phones.
Sai Kalyana Raman
466 次查看
estephania_mart
To reproduce it on my side, and to confirm , you are using the IoT Toolbox, the wireless uart examples and which it's the frames that you are having issues with ?
Which it's that particular wireless uart data that it's causing you troubles?
Regards ,
Estephania
