KV11z- DAC with LPTMR
已解决
跳至解决方案
3,181 次查看
CMooN
I am trying to built a interrupt timer for dac_basic.c . For this purpose, I want to use the logic of lptmr.c and  control voltage produced by DAC. Can someone help me for this ?
1 解答
3,154 次查看
Julián_AragónM
Hi @CMooN,
If your goal is to increase the DAC value in each interrupt, inside the handler you will need to implement a function or flag to check so you increase the value each time an interrupt is taken place.
在原帖中查看解决方案
5 回复数
3,168 次查看
CMooN
Hi @Julián_AragónM ,
Thanks for your answer. I have merged lptmr and dac functionalities together. My purpose is to increase dacValue from 0 to 4095 in 3 seconds. What should I do in the function called 'LPTMR_LED_HANDLER' ?
3,155 次查看
Julián_AragónM
Hi @CMooN,
3,139 次查看
CMooN
Can you please help me about how to init GPIO and to toggle it?
I want to init PTE16 and toggle it i LPTMR.
标记 (1)
3,135 次查看
Julián_AragónM
Hi @CMooN,
In the SDK examples, you can find a project with GPIO initialization and toggle function under "driver_examples" -> "gpio" -> "gpio_input_interrupt".
I hope you find this useful!
Best regards, Julián
3,174 次查看
Julián_AragónM
Hi @CMooN,
The timer handler is used in the SDK example you mention, which will prove useful for your application. You will need to merge these projects to use lptmr and dac functionalities together.
I hope you find this useful! Best regards, Julian
