KV10 单片机复位脚电压异常,严重偏低,而外部阻容复位电路正常,供电电压正常,可能有哪些原因?急!
834 次查看
xianhuli
标记 (1)
1 回复
699 次查看
Hui_Ma
There with the same issue of Kinetis product reset pin if Kinetis product Flash was not programmed.
"If flash is not programmed, the reset vector is 0xFFFF,FFFF , it is a illegal address, may cause reset. In reset sequence, reset pin will drive out"
Customer need program image to KV10 MCU.
Please check below same issue thread for the detailed info:
Problem to program KL05Z - reset_b oscillation
Wish it helps.
Ma Hui
