KL15 ADC VREF Current
788 次查看
RussellPead
I want to verify the TI REF3033 does not exceed the current or voltage tolerance specs.
1) For the KL15, what is the ADC VREF current min/max and voltage tolerance?
2) Are there any recommend external voltage references to use for the ADC?
标记 (2)
477 次查看
Hui_Ma
HI,
1> KL15 ADC VREFH voltage could up to 3.6V, same with VDDA voltage level. VREFL is same with VSSA. There is no ADC VREF pins current data.
2> In general, we recommend to use VREFH = VDDA, VREFL = VSSA.
Customer could check below link about how to design KL15 ADC module hardware and software to get more accuracy performance:
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN4373.pdf
Wish it helps.
best regards
Ma Hui
