KEA128 boot
KEA128 boot
1,594 次查看
fupeng
I'm using keil5 to develop KEA128 chip,  I want to know how to do the boot software and app software.Can you help me?
1,395 次查看
miduo
Please let me know what KEA128 board you used? The NXP board or your customer board?
1,395 次查看
fupeng
      It's our customer board.
      I find some other IDE's bootloader project.I know how to jump from bootloader to application.But how to set the interrupt vector in the application?
1,395 次查看
mjbcswitzerland
Specialist V
There are also KEA128 boot loaders here:
http://www.utasker.com/kinetis/TRK-KEA128.html
http://www.utasker.com/kinetis/FRDM-KEAZ128Q80.html
A guide to application/ bootloader compatibility can be found in the appendix of its user's guide:
http://www.utasker.com/docs/uTasker/uTaskerSerialLoader.PDF
To enter interrupt sat the application there are two methods:
- leave in Flash and set the VBA to the flash location (must be on a 256 byte boundary for KEA128)
- enter in SRAM and set the VBA to the SRAM address (same alignment requirement).
In the uTasker project RAM based vectors are entered with (for example):
fnEnterInterrupt(irq_I2C0_ID, PRIORITY_I2C0, _I2C_Interrupt_0);
Free Open Source solution at http://www.utasker.com/kinetis.html with KEA128 simulation for turn-key KEA128 solution, including Keil uVision5 project.
Mark
