KEA128 + BLE
KEA128 + BLE
1,178 次查看
irmantasbudrys
I am using FRDM DEV BRD KEAZ128 and S32. I have downloaded FRDM-KEA-QSP.zip package in which I found Lab9_BLE_KEA128. I would like to use BLE in my project. Where can I found more info how to start and use this example? Which BLE board this lab example is using?
Thank you.
IB
1,055 次查看
kerryzhou
Hi Irmantas Budrys,
     The relate info for KEA128 can be found in these ways:
1. FRDM-KEA Lab Examples and Board Overview.pdf in the QSP package
Folder: FRDM-KEA-QSP\Quick Start Package v5\SDK Drivers and Code Example Projects
2. Please refer to the ftf document:
http://cache.nxp.com/files/FTF_2015/ftf-acc-F1112.pdf?fsrch=1&sr=2&pageNum=1
Wish it helps you!
Kerry
1,056 次查看
kerryzhou
Hi Irmantas Budrys,
Wish it helps you!
Kerry
