The following register has xxxDIV1 field, but I cannot find out the peripheral module that uses the clock divided by xxxDIV1 field.
- SCG_SOSCDIV: SOSCDIV1
- SCG_SIRCDIV: SIRCDIV1
- SCG_FIRCDIV: FIRCDIV1
- SCG_LPFLLDIV: LPFLLDIV1
Which module uses the clock divided by xxxDIV1?
If no any module not uses the clock divided by xxxDIV1, please delete those fields or change to reserved fields.
And, please tell us revise schedule for reference manual.
Takashima
Hi Takashima,
I can only find out the peripheral module that uses the clock divided by xxxDIV1 field in KE1xF reference manual.
Sorry for the inconvenience!
Robin
Hi Takashima,
The FLLDIV1, SIRCDIV1, FIRCDIV1, SOSCDIV1 are not used, will reserve these fields in RM.
