Hi Raul10,
About the FlexNVM EEPROM backup size question, I used the 8 times backup size to test it in the K20D72M before. The eeprom can work.
I think, 16 times is mainly to ensure the endurance.
So, to ensure the eeprom write endurance, you should better to refer to the RM, make sure 16 times backup size, otherwise, you don't know what the write endurance.
From the datasheet, you can find all the data is based on the 16times backup principle.
Wish it helps you!
Kerry
