KE16F Vs. KE18F
KE16F Vs. KE18F
995 次查看
JRIIS
Customer asking about the implication from a technical point of view if they change their design from the MKE16F to the MKE18F.
This should be the same die so it should be fine to use both as long at they compile to the actual version.
Could I kindly ask for validation on this please?
/Jakob
标记 (1)
975 次查看
JRIIS
Hi Jing,
I need to understand all deference in detailed, when you say main difference is memory size then you indicate that there is other deference. Could you please point those out?
/Jakob
966 次查看
jingpan
KE18F has 2 CAN while KE16F has 1 CAN.
That's all I think.
Jing
984 次查看
jingpan
Hi Jakob,
Yes. Their main difference is memory size.
Jing
