KBI pinout in kinetis M
1,098 次查看
andresbaena
hello
the kinetis family m, not have KBI interrupt.
thanks
标签 (1)
标记 (2)
1 回复
890 次查看
PatriciaTeran
hi, Andres
The family M does not have it by the name of KBI interrupt, but you can use GPIO as an interrupt. If you go to Chapter 11 of the Reference Manual, you can find more information about how to configure it, section 11.5.1 describes the Pin Control Register, where you can configure the pin to generate the interrupt request
You can also refer to eGPIO which is described in section 3.10.1
Hope it helps
Patricia
