Hi vignesh balaji,
You can use 2 KBI pins in one KBI module, but you should take care of this point in the reference manual:
So, if when one KBI pin is in asserted state, then another KBI pin detect the edges in the same KBI module may be ignored, that's why I suggest you use two pin in different KBI module .
Wish it helps you!
If you still have question, please contact me!
Jingjing
Thank you Jing,
I controlled 2 KBI pins in the same KBI module by flipping the polarity of edges inside the interrupt
