K66 - SAI - 2 data lines
769 次查看
Argail
I'm looking for some clarification on how the SAI module works on the K66 MCU.
There is only one SAI on this device but the datasheet says there is 2 Tx data lines and 2 Rx data lines. Does this means I may connect one GSM module with I2S interface and one monaural I2S audio codec on the same MCU and at the same time?
764 次查看
jingpan
Hi Argail,
There is only one TX_BCLK and one RT_BCLK. If you have two devices and both need RX and TX, they have to share same TX_BCLK and RT_BLCK. Their data is independent.
Jing
