K64 Sub-Family Reference Manual disappeared
2,857 次查看
nestordamiangar
Hi everybody,
Today I was looking for the datasheet of the MK64FN1M0VLL12 chip because I wanted to learn about its registers. So, I remember some months ago, I got the following document titled: "K64 Sub-Family Reference Manual". There are detailed info about the peripherals for the FRDM K64F board, however today I tried to get it from freescale page and I didn't find it.
Now it is only available one pdf with the electrical specs...
Do you know why it dissapear? Do you know if there is another document with more information about the memory map and so on?...
Thanks in advance.
1,177 次查看
Hello Nestor,
Here is the RM, please check :
  http://cache.freescale.com/files/microcontrollers/doc/ref_manual/K64P144M120SF5RM.pdf?fpsp=1&WT_TYPE...
Hope it helps
Alice
