K61 and K70
K61 and K70
1,714 次查看
sithara
Are the kinetics K61 and K70 processors pin compatible?
Is the K60 and K70 twr module be used to evaluate K61 series?
1,626 次查看
Paul_Tian
Hi, Sivan
Thank you for your feedback. As I mentioned, on 256pins package, they are pin compatible.
Best Regards
Paul
1,626 次查看
Paul_Tian
Hi, Sivan
Although I do not know which package you want to compare, but I compare 256pins package for you. They are pin compatible.
Hope my reply can help you.
Best Regards
Paul
1,626 次查看
sithara
Sorry...I want to know 256 pin itself..Thanks...
1,627 次查看
Paul_Tian
Hi, Sivan
Best Regards
Paul
