K60 SPI Salve Mode Error
863 次查看
tomzuojin
When I used K60 worked on SPI Slave mode, normaly those worked OK,but when the electric contactor turn on or off,
the SPI bus recieve data is error.
 I uses 16Bit mode ,and 1Mbps rate,and every word is CS.but the error is coninue.  and Slave  worked on interrupt function recieve the data.
who can help me to solve the problem.
783 次查看
Hui_Ma
Could you please provide more detailed info about K60 SPI slave issue?
It will be much helpful to understand the issue if there with SPI communication data/signals.
Thank you for the attention.
Mike
