K60 SDHC Module CINS Bit in PRSSTAT Register is always 1 !?
1,200 次查看
monXii
Hello all..
I'm using a micro sd card and my card holder has no card detect ..
so i want to use the software bit CINS (card inserted) in SDHC->PRSSTAT ..
but this bit is always 1?
did someone used this bit successful?
how this bit works internally? how do they "detect" the card?
720 次查看
monXii
hey all.
i found 2 mistakes..
one on my side .. one on mqx side :smileyhappy:
first of all the GPIO init of the SDHC pins was "wrong" ..
for card detection over the pin levels, pin 1 (DAT3) of the sdcard must have an pull-down on the host side.
            pctl = (PORT_MemMapPtr)PORTE_BASE_PTR;
            pctl->PCR[0] = value & (PORT_PCR_MUX(4) | PORT_PCR_PS_MASK | PORT_PCR_PE_MASK | PORT_PCR_DSE_MASK);    /* ESDHC.D1  */
            pctl->PCR[1] = value & (PORT_PCR_MUX(4) | PORT_PCR_PS_MASK | PORT_PCR_PE_MASK | PORT_PCR_DSE_MASK);    /* ESDHC.D0  */
            pctl->PCR[2] = value & (PORT_PCR_MUX(4) | PORT_PCR_DSE_MASK);                                          /* ESDHC.CLK */
            pctl->PCR[3] = value & (PORT_PCR_MUX(4) | PORT_PCR_PS_MASK | PORT_PCR_PE_MASK | PORT_PCR_DSE_MASK);    /* ESDHC.CMD */
            pctl->PCR[4] = value & (PORT_PCR_MUX(4) |                                               PORT_PCR_PE_MASK | PORT_PCR_DSE_MASK);    /* ESDHC.D3  */
            pctl->PCR[5] = value & (PORT_PCR_MUX(4) | PORT_PCR_PS_MASK | PORT_PCR_PE_MASK | PORT_PCR_DSE_MASK);    /* ESDHC.D2  */
and my mistake:
i have to set the INITA bit in SDHC_SYSCTL to refresh the PRSSTAT information..
721 次查看
monXii
hey all.
and my mistake:
