K21F USB issue
K21F USB issue
3,189 次查看
AlvinLin1933
When use K21F to replace K21D, USB can't communicate with Tablet and the other device, the buzzer and LED function can work, try 5pcs, the issue is the same. would you please advise how to fix it ?
5 回复数
3,154 次查看
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, could you elaborate further about the communication through USB? Are you using the same bin, or do you have 2 different compile projects?
I say that because the MCU has a different frequency and needs to use the appropriate compilation, 120 MHz vs 50 MHz.
Pavel
2,959 次查看
AlvinLin1933
Hi Pavel :
    After completed the programming, Tablet can't recognize the USB K21F device.
2,929 次查看
Pavel_Hernandez
Hello, sorry for the late response I found on the SDK builder the K21F has an example on the SDK, could you try any example that your similar application, I want to know if the behavior is the same.
The other thing could you elaborate further on the issue?
Pavel
2,918 次查看
AlvinLin1933
Hi Pavel :
    Please refer the enclosed png, when set the USBx_USBTCR0[USBRESET] bit manually, it seems fix the USB issue, would you have the other suggestion ?
2,883 次查看
Pavel_Hernandez
Hello, I found the following thread maybe could help you.
Delay needed before setting USB0_CTL? - NXP Community
Pavel
