K10 using I2S MIC.
K10 using I2S MIC.
1,083 次查看
c393
I have a K10P144M120 design. I have a I2S MIC connected to I2S1_RXD0, I2S1_BCLK and I2S1_RX_FS. Can I configure the SAI module for receive only? Do I have to configure the transmit?  It appears that the RX BCLK source is from the transmit BCLK. Can I configure the transmit but do not configure the I/O pins?
标记 (3)
918 次查看
Paul_Tian
Hi, Dennis
Yes, you can configure it as receiver only. For your last question, I cannot understand it clearly. Would you please to make me clear? Thanks.
Best Regards
Paul
