Issue with flashing the program due to reset pin low on KL05Z32
1,559 次查看
sureshjaggal
Dear Folks,
The reset pin is connected to internal pull up according to the that datasheet.
The reset pin on my PCB measures 1.5 Volts, but  I am expecting 3.3v  due to which i can not Flash my microcontroller.
The reset pin measures 1.5v when connected with a 3k resistor and  2.5v when connected with 1k resistor  (Please find the resistor circuit in the attachment).
I can Flash my microcontroller when the reset pin measures 2.5v.
Questions
1) Why does the reset pin measure 1.5v when we have 3k resistor.
Suresh Jaggal
标记 (2)
1,454 次查看
Robin_Shen
Hi Suresh
I am not sure whether you have observe the waveform on reset pin by using oscilloscope.
If the waveform seems periodic oscillation, you may check the RESET_b pin and the NMI_b pin.
You can check the circuits according to the "2.1.3.4.1 RESET_b and NMI_b" of KLQRUG.pdf
Best Regard
Robin
